How are the temps? Noise/fan speed?Didn't see the question until now, too late although i will have a look tomorrow.
Work in progress.
Around 33cm with one 140mm installed at the bottom front, around 20cm with both.
thanks- I have 4x3.5 & 2x ssd drives along with a AE6 that would go in the top 5.25 bay that I would need to use so might check one out
Hey shad any chance you could let me know if there is clearence, due to offset, that a total of 65mm rad and fan would most likely miss vrm heatsink and ram on topIf you have a long graphics card, like me, then bear in mind that you lose a couple of hd slots.
