Thank you for that but in one sense that's even stranger as Ive just confirmed that I'm on 1013 already (I couldn't remember exactly, but it was updated in the last few days)
I still cant play WestWorld S1, The Dark Knight or Interstellar (the latter two don't even start playing, saying they don't conform to the standards)
the K8500 wants to play Westworld but its impossible to get it to run smoothly(not dissimilar to a stream that isn't running fast enough)
Interestingly on My Xbox One S - the two Nolan discs play perfectly (only tried the first minute or so of each but so far it looks brilliant)
Westworld looks / sounds slightly better on the One S but still totally unwatchable
I'm just relieved that its definitely a firmware issue , even though I was really looking forward to watching WW over Xmas / New Year
Still very strange how you are able to play TDK totally ok but on the same firmware its totally unplayable here.
I was going to do this at work today, but unfortunately Samsung insist on a serial num
ber before even logging the call - but now I have it confirmed its a firmware issue I'm slightly more relaxed about it
Because it cant be a disc issue (as it plays ok in another device....or at least starts to , more below) , and the Samsung player has played 45 or so other UHD discs ok, including some as new as the problematic ones (like Batman Begins . Prestige / Dark Knight Rises as well as previously released ones).Why do you think its a firmware issue when mine is okay ? I did a google on the error and found numerous pages. Half of generally point to a faulty unit, a few to the HDMI cable, a few to the disc, some more solved with a full power off at the wall, power on and a couple mention they cleaned the Samsung laser head and this cured it which was interesting.
Its unlikely to be a cable issue as surely that would effect all disks asurely? I will try swapping cables around but I just don't see it being this (but more than happy to accept my doubt ass wrong)
(I know there are different quality cables, and able to pass/ or not high Mbps etc) but again surely this would have been apparent with Blue Planet II / La La Land or other new releases?
After about 30 minutes the One S started dropping frames and the picture started getting really blocky - suspect this to be heat issues or something rather than disc related.
After a little advice guys,
Just got my first 4K tv and have upgraded my PS4 to the Pro... but as you all know they didn’t add a ****** player into it.
I have a max budget of £200 but I don’t know which player in that budget is best? Is it worth looking at one of these Apple TV 4K units? As the movies on there seem to be pretty well priced.
Yes it is so worth looking at the Apple 4K tv box, i got one last month and have not looked back my poor Samsung k8500 UHD player has not been used since lol.
Most 4K films are Dolby Vision too which is what also swayed me to move and the prices of course .
Very few are real DV. The rest are just converted.
Interesting to know so they are converting HDR movies to DV ? do you have a link to what is true DV or not?
this is not difficult no ? they just have to analyse scenes and establish min/max brightness levels to embed in the dv metadata ?Interesting to know so they are converting HDR movies to DV ? do you have a link to what is true DV or not?
