Caporegime
- 18 Oct 2002
I am just saying that I haven't noticed as big a jump in performance as I was expecting.
Freesync would have helped *lots* in that regard!
I don't know. Going forward I might notice a bigger jump? It will be a while before I can afford a Gsync monitor!!
I thought ther Ti was around 70% or more faster.
Pretty sure upon release, they were talking around 60-70% slower than the Ti.
A Vega 64 Liquid will do about 10-12%~ faster than an AIC 1080.
Than an FE maybe, but not an out-of-the-box overclocked 1080. Also the Ti is roughly 35% faster than the 1080 (Fe and overclocked).
My little 56 will beat any 1080.. post a score and i'll show youHmm, most of the RX Vega benchmarks are usually balanced mode. When I count RX Vega, I see it as 1600 MHz/ 1050-1100 Mhz HBM and compare like that.
I am sure i had a 48xx on my 56 before i nuked it![]()
I just picked the highest score in the bench thread to see if you could as there are no 56's above the 1080 in there
My 56 is on a lc bios with watercooling.I just picked the highest score in the bench thread to see if you could as there are no 56's above the 1080 in there[/SPOILER]
I got 4448 with amd blockchain driver (as thats what was installed when i read your post) 1756 1100 hbm
But only get 4112 with the newest driver 1722 1180 hbm
I don't understand how people are getting 5299 on a vega 64 with only 1777 core and 1105 hbm.... it's baffling me. My cpu is clocked higher
https://benchmark.unigine.com/results/rid_79302e77e41145e99f3983042ef88df7
I don't believe it.
I can beat the 1080's though if i roll back to the 17.10.1 driver or whichever it was that was the damn fast one a few months ago. seems like performance from the drivers is going down not up.
Here you go...![]()
Im on itLets see then, Need to walk the walk when you say
Thats the same i can push mine too but the scores arent as good as on previous drivers with much lower clocks and hbm..... weirdIf someone knows how to run 16:9 Superposition 1080p (like it does on 4k optimized) on my 21:9 monitor, I can try these too. My all out profile is 1750 Mhz / 1180 Mhz.
For reference I get about 7168~ or so post-Adrenalin on 4k optimized.
I love youHere you go...
Ironically, score number 56 at present too.
Vega 56 1709/1090MHz
Ryzen Threadripper 1920x @ 4GHz
Crimson 17.11.2
