- 23 Oct 2013
but with tubeless and lower pressures the wide tyre has more surface area and thus more tread to grip (for the same tread profile). Sure, there's no denying that in mud a bigger spaced out tread will grip better than close little nubs, but width helps too (says the actress).Tread pattern > width
. Not sure if they went back in perfectly, might end up having to buy a new seal set.
