**** The Official OnePlus 5 Thread ****
4 May 2007
West Midlands
I think should answer your question about buying from eglobal
https://uk.trustpilot.com/review/eglobalcentral.co.uk
Hah I just seen that! Absolutely no from me then. I I considered a honor mate 10 from john lewis for £380 but heard the camera on this is better?
How is the camera on this and does it hold up to low end dslr? I have a micro 4:33camera. Big camera improvement on samsung note 4? (which I think is very good.)
Does the one plus 5T have 8gb ram? I've seen one here? Is the warranty from the manufacturer good?
https://www1.techinthebasket.com/on...bjsMPu4_PAamzXWVpABKEsui7B47V5F0aAqMjEALw_wcB
Wheres best to buy it/cost?
8 Jun 2007
Any of those chinese sites the warranty is with them so effectively useless.
Oneplus don't give you warranty they send you to the seller.
Best place to buy is OP themselves or O2 if you want warranty.
19 Jan 2006
agreed - buy from O2 or direct from OP. Don't bother with chinese sites etc.
19 Jan 2006
Those on Oreo (one plus 5) - Can you tell me where I can select/change/option for 2.4ghz/5ghz wifi. I can't find it anywhere.
Phone is on 2.4ghz and seems no option to select 5ghz or even the option to have it switch between them etc.
Permabanned
13 Nov 2005
Not much has been changed, doesn't feel any different and looks only slightly different, it's just another over hyped Android update.
VPN method never worked this time, had to download and install via recovery.
EDIT - Anyone know what they changed from 5.02 to 5.03? Seems they rushed out a small patch for something.
