Took me a few times of connecting to Canada before it picked up the update.
Thanks, have done a tour of the world with tunnelbear but still not picking it up. I'll have to wait and keep checking.German VPN![]()
Thanks, given it a try, still no luck I'll wait it outuse Opera VPN (free app) - connect to Canada, then check for updates. Works everytime for me.
If you buy from somewhere like here do you keep the warranty?
https://www.eglobalcentral.co.uk/on...0VgM-JkFHTT_whIGQaAmxoEALw_wcB#/product/22681
Hah I just seen that! Absolutely no from me then. I I considered a honor mate 10 from john lewis for £380 but heard the camera on this is better?I think should answer your question about buying from eglobal
https://uk.trustpilot.com/review/eglobalcentral.co.uk
Any of those chinese sites the warranty is with them so effectively useless.
Oneplus don't give you warranty they send you to the seller.
Best place to buy is OP themselves or O2 if you want warranty.
This is how I have mine.I don't think there is an option.If it sees a 5G network you can connect to it.
On my router i renamed the 5G network 5G so connect to that.
