Hi there - whitelisted!Ohhhh can i get whitelisted please not played minecraft for a what seems like forever !
I think my name is Elbulus
Had a breakthrough re the lag - will update when I get back from the school run!
Edit: OK - so I've a little more time. Petridish5 - it's just the MC instance that restarts, not the VM - I don't have the option to do that afaik. Like you, I'm at a loss as to why loading the same, but older version of the world, then reloading the recent version works. Most odd.
Anyhoo - O frabjous day! Callooh! Callay!
I did the above last night, than as I said I have un-chunkloaded everything and moved spawn to unload some of my build last night at 19:00. Right now as of 16:38 the server is running 100%. Yesterday the lag appeared after about 8 hours, it's been up about 21 hours now and touch wood, we're all good. I'm going to leave the areas unloaded for a little while longer just to check, and then I'll see about chunkloading chunks one by one until I find the issue.
I have noted down all the loaded chunks, so no worries there. Again, just for the time being, can we hold off on chunkloading until I find the machine causing the probs. I've got about 13 chunks to check, not including my place (I'll worry about that later).
Thanks all for being understanding. Looks like we're getting somewhere now - happy days!
 Ta
