Caporegime
- 18 Sep 2009
- Dormanstown.
Bulldozer? Bulldozer was a heap of ####, Intel's IPC was higher across the board, no ambiguity about that and its right to blatantly say with that "Intel has higher IPC" its true.
Ryzen is not Bulldozer, we are talking about Ryzen and Ryzen has SMT, you can't just make it go away.
Okay.
You say IPC is IPC.
If an application maxed out all 6 cores on the 8700K and the Ryzen 1600 (At the end of the day, this is a scenario that does happen in the real world. You can't force software to use more threads than it's capable of doing). But *didn't* to go the 7th thread onwards. At the same clock, is Ryzen performing the same as the 8700K?
