Deleted member 70857
I think the main problem will be for people using the Model 3 as a taxi, or any sort of ride sharing. The door handle is so uncommon that I don't think many people will know how to open the door!
If my Model 3 was being used in ride sharing/uber then I would have a sticker/label right by the button on the inside instructing people to use thatI think the main problem will be for people using the Model 3 as a taxi, or any sort of ride sharing. The door handle is so uncommon that I don't think many people will know how to open the door!
If my Model 3 was being used in ride sharing/uber then I would have a sticker/label right by the button on the inside instructing people to use that![]()
Ah right ok. I can't see it taking more than a few seconds to figure out though? Go up to it, not obvious, push the metal bit, see it move and figure it from there?I was thinking about the outside handle
There must be a safety feature that stops the inside electronic door releases being used when the car is in motion. I could say many people getting the door release and window buttons mixed up.
I am guessing because the latch for the door is electronically released. If the car is frozen shut then the latch might not release...causing problems? I guess?I don't understand what that would happen?
Seems like such an easy thing to implement seeing as they already have scheduled charging
Exactly what I would say. I know hardly anything about the app but surely (if not already there) they should add a scheduled pre-heat option?
If you know you leave for work every day at 8,you could schedule a pre-heat 30-60 minutes before that.
Matter of timeOh yeah, I know you can do it from the app .But you just can't schedule it.
