- 13 May 2003
It will surprise some people but I approve of unions and this is one of those situations where they are extremely useful. But I'm guessing you have no unions at your place of work.
I work in an office that is part of a larger building which is just about to get a new landlord (old company went bankrupt) and there has been questions raised over the fire safety of the whole building (new company are doing their assessments) but who is the responsible party for my office?
We basically have one water fire extinguisher (and lots of electrical equipment) which was last tested in 2005 in the office and no clear/explained/documented fire escape procedure, I just asked my boss and all I got was it's down over the roof into the back of a load of buildings and open a door with a key that leads into another business, he has never showed me any exit plan or anything and naturally now I am curious as to what happens in a fire, should I be pushing my boss or wait until the new company come in and do the required improvements?
Allow me to clear up, there's generally some good advice here but I'll fill in the blanks.
The Regulatory Reform (Fire Safety) Order places duties on the responsible person. In other words, your boss carries the operational duty of fire safety as he is in control. The landlord is responsible for the upkeep and maintenance of the alarm system and fire risk assessments.
Water extinguisher is used for combustibles and textiles. You want CO2 or dry power for an office with electrical equipment. Unless you want to throw all your electronic equipment out though I'd go with CO2. Again, the number, placement and type should be determined by the risk assessment (normally in accordance with the British standard).
Electrical items do NOT need to be tested annually. This is a common H&S myth. The electricity regulations state that they should be tested but gives no guidance on frequency and does not explicitly require you to even keep records (but obviously that's a good idea). Most businesses will PAT test once and rely on user / visual checks. We are duty bound to investigate instances such as those outlined by the OP. There are a few differences as far as legislation is concerned between England & Scotland but it's fundamentally the same, essentially.
You CAN lock an emergency exit door if there's justification in a risk assessment but usually it 1) has to have an emergency key / override linked to the alarm system nearby 2) theres normally other exit routes within the permitted travel distances
Emergency planning, policy and drills is covered under the RRO so really it's pretty basic stuff. The fact you don't know it or haven't been told on induction is pretty worrying but keep on to them and see what they say.
@Scania... I can't speak for them but it's likely because discharging a CO2 extinguisher in a confined space would be a bad idea. Not saying you would... But they have to inform staff not to do that before they "go live". Information, instruction and training etc etc.
A large warehouse that I used to work at, T.H.E. in Chesterton, used to chain the emergency fire exits shut to stop people nipping out for a smoke or pushing goods through the fence so they could come back later and pick them up after their shift.
How that place never got shut down is beyond me. Rumour was, they used to get prior warning of inspections so they could remove the chains.
There's no emergency lighting or anything in the whole building, one of the things that the guy last week from the new company mentioned needed changing.
There was a fire alarm system installed last year (which get tested regularly) by someone, but as far as designated assembly points go etc, risk assesments there is nothing.
How should I push this to get the attention it needs?
Hardly the same but at work our recently delivered new Volvo HGV's have all had their standard fit fire extinguishers removed, when asked why the reason is for health & safety reasons as we haven't been trained how to use them!!!!!
I'm all for H&S but crap like that you couldn't make up!
Could they bot jist have a 30 miniute trianing session?
Read out the label, show how to take the pin then give you all ago spraying a target on the flolr.
Done?
You should have designated fire marshals and perform drills. If you have extinguishers then selected people should be trained in their operation (which includes things like how to select an appropriate extinguisher).
aside from that, it seems the only extinguisher they have is the wrong type!Responsibility of the employer, not the landlord in commercial premises.
SHocking to not have enough fire extinguisher, fire warden, fire exit signs, emergency lighting, risk assessments, fire alarm and drill tests, designated assembly point, etc
As well as it's illegal and HSE would be down on them like a tonne of bricks and if there was a fire tomorrow and somebody died then your boss would go to jail for a very long time.
