- 23 Mar 2011
So if i get a hdmi converter that will do the job, i dont really want to spend loads and loads of cash but connecting via hdmi would suit
For ps2 and Wii I bought a small HDMI adapter known as "PS2 to HDMI" and "Wii to HDMI" they range in price all around £8ish. Does the job, essentially on par with a Component connection, minimal difference really. It pretty much taps in to that signal and just sends it out via HDMI instead.
With ps2 mind, you first need to plug it in via composite (red yellow and white, or scart) because you need to change the output in the system settings. Then you can use the HDMI adapter. If you don't do this, you won't get a picture only sound
Also check your modern tv supports the resolution for these systems. 480i/p I believe?
