- 30 Nov 2011
vsync should always be off in game
Why?vsync should always be off in game
Why?
I just leave it on application decides, set it to in usually and gsync is still working fine - fps matches refresh when i check on the monitor.
The last article i read it advised to set gsync and vsync on in the NCP
G-Sync disables once your frame rate hits your max refresh rate.Why?
Why?
Why?
So if you have V-Sync enabled this will take over and introduce more lag.
If V-Sync is disabled when ever your frame rate hits or exceeds your maximum refresh G-Sync gets knocked off and this introduces screen tearing.
G-Sync enabled with a game FPS cap (2fps lower than refresh) and V-Sync disabled everywhere is the best setting for using it...
This is the best way and works fine, I cap to 116FPs and leave V=Sync off at all times in game and NVCP
Rivatuner with AB is what i use if the game has no tools to capHow do you set the FPS cap?
I’m using riva tuner which installs with msi afterburner.How do you set the FPS cap?
Show off! I'm not jealous!Just got myself the Acer X34P 120Hz G-Sync Ultrawide Curved IPS, G-Sync is love, G-Sync is life
Nice Dom. I have the 100Hz X34 UW and can't see me moving on for a long while. Love the UW and 100Hz 3440x1440 looks amazing.Just got myself the Acer X34P 120Hz G-Sync Ultrawide Curved IPS, G-Sync is love, G-Sync is life
