Neither do I.I don’t need either to take one set of wheels off a car and put another set on. All I need is a jack (one of theses usually comes with the car) and a wrench with the right size socket for the but (which also comes with the car). Ideally a torque wrench is a good option too, and you can always get a small bottle jack or trolley jack if you aren’t keen on using the jack that comes with the car.
Having two sets of rims is much cheaper in the long run because you’re not having to pay someone to swap tyres over every time. A set of “winter” rims is cheap too.
Edit: I see I wrote “tyre” in the first post in this sequence. I meant wheels with different tyres, which I presumed you realised from your previous post.![]()
What I mean is that although I'm perfectly capable of changing wheels myself, I have to take it to a shop to change the tyres every so often, and in the process they often over tighten bolts / damage wheel nuts which then makes it difficult for me when I want to change a wheel myself to put on winter wheels / spare wheel etc. Probably wasn't very clear, sorry!
