- 18 May 2010
- London
First 8K TV to go on sale in Oct. Only £86,000!
He added that for the time being, he expected manufacturers to focus their efforts on trying to convince families to buy 4K sets instead.
They provide a quarter of the resolution of 8K, but are being made in sizes of up to about 100in to create "cinema-like" experiences in the home.
4K TVs offer four times the number of pixels as 1080p HD sets, but a quarter as many as 8K TVs
I'm either tired or someone needs to badly check the math ! Thats the BBC for you.
(check the diagram on that page too !)
Add: Yep think I`m tired.
lol.... yep, that's marketing for you. 4K sounds sexier than UHD, and AFAIK they haven't yet coined a term for 7680 x 4320; Hyper-HD perhaps?
8K Super Hi-Vision http://www.nhk.or.jp/8k/index_e.html
I'd take this with a pinch on salt as scroll down and they are calling 4k - Hi-Vision (HDTV) or should I say "Hi-Vision Definition TeleVision" and its definitely not marketed under that name !
So if people keep bringing up that same old chart the one saying your eye cant see 4k detail unless its x metres away ie you dont benefit from 4k @ 55" unless its 2 miles away does that mean if you have an 8k TV you wont benefit @ 55" unless its 4 miles away from the seating area? SO 8k is pointless unless you buy a bigger house with bigger lounge ?
Guess you gonna need a new chart.
When is UHD 4K?yay marketing.
I wonder how many folk so far have bought a UHD TV and are using it with SD and HD sources but have convinced themselves they're watching "4K" everything? Same sort of thing happened with the transition to HD. All just a little bit of history repeating....![]()
No, it is the opposite, the higher the distance from the screen, the less likely you would notice differences between lower and higher resolution content.
When you sit 50 cm from a 55" screen, you need higher resolution in order not to see the pixels themselves.
