Man of Honour
- 21 Nov 2004
How do I delete cables once layed e.g. once a resource has been depleted?
Go to your build menu, the option on the left side, that looks like a military stripe, click on it, then on the far right side you have the option to delete cables and such. Not in game for now so don't know the proper descriptions, but there is where you find it.How do I delete cables once layed e.g. once a resource has been depleted?
Is there better power generation later? I either burn through machine parts of metals!
They don't need maintenance when closed ?? Wish it would say that, although at 12 Polymers and 6 Electronics they not that cheap to make (or 400 Mill per Generator, if buying them)You can ship Stirling Generators which are amazing. You can keep them closed and they will generate 10 power with no maintenance needed. You can open them and they will generate double but will also need maintenance with polymers if you do.
Wouldn't mind this, be interesting to see if things the same. My coordinates on the only location I played so far is 2 South, 130 East. Sponsor Europe and Commander is Futurist. All depending if you meaning exactly the same or not. Difficultie is not that high at 185% though.You can't play this game in multiplayer but the resources we all see are probably the same. Would be interesting to play the same co-ordinates as other people and compare notes![]()
Yes, or the larger storage platforms, depending on how much resources you have around the area. Also, overlapping a dome helps with maintenance of it, or other important factories etc. I just started doing it at one location on my map, see how it works out.So it seems to be a good strategy to overlap drone command range slightly and to put a universal storage in the overlap area - the drones then seem to share out the resources?
Does gardens help with that or need to be like casino and such ?Okis.. this is less fun. Game just throw me a curve ball. Something, probably a random "tornado" must have disabled my mobile drone unit, and no drone station is within range for it. Soooo.. had to spend what little money I had to buy a new one, so I can repair the old one !![]()
And on a slightly lesser note, how do you improve morale ?? Got that message at the same time my mobile drone unit broke down. Obviously one problem is not enough ehh !Does gardens help with that or need to be like casino and such ?
You can repair the rover by clicking it with a drone i think.
Nuclear Fusion, and if lucky there is a breakthrough advancing it further.Didn't even know that was there, thanks!
My colony sort of fell apart when my machine parts stop being manufactured. I don't know what I did wrong but my first dome lost all it's workers and no one wanted to work in my machine parts factory, so I stopped being able to make them, couple that with shortages of metals due to maintenance, food shortages, and serious water supply issues (I had 6 vaporators in the end, but they don't work in dust storms). I'll need to re-think how the last one went!
My RC Rover got smashed today also, and it was at the first base where creating concrete and half the fuel.
However that didn't matter. Turned off everything including solar panels as it was separated from the first dome base. (one of my tips above...).
I sent the rocket who had just brought colonists back to earth. Loaded with 5 electronic parts I had money for, and sent it pack to Mars. Landed the rocket near the first base inside the RC Rover drones position. They woke up. Went into the rocket to charge, then repaired the Rc Rover. Unloaded the electronics to the Transport and sent the electronics to the dome.
Job done.
Last part. The location of map is same between two games eg 23N 2W, but all resources, anomalies etc are random. So is the quest line.
(I need to check if they used proper topographical map of Mars from NASA)
You can click a colonist and find out whats wrong. I had 20 suicide on my second game, and 13 left the planet leaving me in whole dome with 1 happy colonist. They had some huge negative malus because of water and power shortages, which aggravated them more having an icing snap at the same time.
My experience is that the resources are always the same, if I pick a co-ordinate then I always get the same resources in the same place.
I just don't know if the resources are the same between different players or not?
Job done.
Game can be addictive ! Tomorrow got to make a dome close to some deep metal deposits, running out on the stuff.
I played twice 23N 2W, the resources were in different places, so was the starting position.
Weird for me each time I play a map I seem to get the exact same resources in the same places.
When you said this, "You place 5 big solar panels, cement, fuel refinery and moisturizer. Set everyone to work on the two morning shifts, and scan the crap of the area". I wonder what the logic behind adding 5 solar panels to your fuel/cement loop was? If you have the mentioned buildings you need 15 power, 3 panels would generate that. In a dust storm those 5 panels will drop down to a combined 10, which would only power 2 of them, I guess you could probably turn off the concrete in that case. In a freeze all of the buildings would freeze over in the night and require extra maintenance to bring them back after.
A common problem im having is getting people to work where I need them.
Despite having high priority and plenty of population they suddenly all just dont want to work in a particular building which often leads to a colony's demise over time.
