Ryzen "2" ?
24 Feb 2003
Stourport-On-Severn
It all seems good, it will be nice if AMD can launch these without as someone put it earlier, snatching defeat from the jaws of victory.
Just how can AMD get this wrong, with the decent leaks, it is all looking rosy.
It would actually be a good launch if AMD stick to the launch.............................................................ie, don't bring out out a 2800X a few months down the line. That would put them in the same "milking" bracket as Intel and Nvidia.
28 May 2007
If true then its great to see them become cheaper.
I recon the 2800 is only a couple of months away, being saved for a big clocks release to counter intel - with a much higher price than the rest of the range.
Not sure what Intel could offer up as competition though. They can't match anything AMD have now, never mind faster versions offering better value.
I think Intels main focus over the next 3 years will be the graphics market.
31 Aug 2017
Maybe a desperate attempt to win back the top of the review charts, assuming AMD takes it which is another thing entirely.
An 8750k maybe with 100Mhz bump?
A higher clocked 7820k, say 4.5 Ghz turbo...
Amd could return with a 4.5Ghz turbo 2800x
28 May 2007
Until Intel drop the ringbus and find a way to scale over cores they get beat.
Permabanned
2 Sep 2017
Except that in many applications, the difference in Ryzens' favour is so enormous, that no 100 MHz would do anything to remove it.
Yes:
The difference between the green bars, between 106 and 27 is 3.925x.
https://www.notebookcheck.net/AMD-R...-review-available-from-April-19.289396.0.html
31 Aug 2017
In some applications yes its excellent, however in some others it is not - gaming ... which apparently according to many on this forum and the rest of the web is all that counts, the old 1st gen chips aint touching the intel chips (raw Mhz and a little better IPC)
So as gaming is the most important application any CPU can ever be used for - sod supercomputers, server farms, clouds, rendering, bla bla bla - will intel want to get the crown back if the 2700 takes it.. which it prob wont.
/sarc
28 May 2007
/sarc
It's neck and neck in gaming TBH.
30 Jul 2004
Auckland
I am really looking forward to seeing how the 2600x stacks up now. I dislike comparisons against chips that are two generations old - it feels disingenuous, I suspect that a month from release we are still going to be seeing driver development and they have kept the review like this so that they can re-edit if needed.
Price wise the 2600 is going to be all kinds of compelling. It looks like it is going to be very close to 8700k performance in an i5 price bracket.
Permabanned
2 Sep 2017
/sarc
Gaming is the last point for justification of i5s and i7s sales. If they lose that, it is game over.
This is why they are holding for it so desperately, it's life saving.
Caporegime
20 May 2007
Surrey
Would be better if there's done benches for something newer that a 6700k from 2015 tbh
This. The 2700x should be benched against the 8700/8700k as they are in the same sort of price bracket, not an EOL 6700k :confused: Seems rather pointless to bench AMD's new 2018 stuff with Intel's 2015 stuff.
Permabanned
2 Sep 2017
Err?! Two mistakes - first is that i7-8700K was released in Q4 2017, which means i7-6700K/i7-7700K was the latest and greatest thing till Q4 2017, nothing about 2015.
And second - the Ryzen 7 2700X has to be benched against an equivalent 8-core / 16-thread chip from Intel. Any suggestions which one it should be?
Caporegime
20 May 2007
Surrey
What? :confused:
5 Nov 2011
Derbyshire
And that is the perpetual grey patch that means you can't "actually" bench them against one another. Ideal world, bench Intels top end i7 against AMD's top end Ryzen but the AMD fan bois will cry that it's not fair.
I want to see "real" benches of a stock 1700X vs a 2700X. Let that be the first difference, show an improvement against your own product before you go onto the offensive at another brand. Intel have a batter single core performance, Ryzen will naturally have better multi core as it has more cores. Yet more grey patches because X application uses multi cores better than Y.
There will always be pros and cons of each, I just hope that the gains over their own product are worth the hype train building.
Caporegime
1 Jun 2006
Notts
you think ryzen two are beating intels in gaming you in cuckoo land. thats why multithread is being marketed more.using the strengths to sell it not its weakness.
