- 10 Nov 2006
Anyone have the above?
Long story short, Ordered a new conservatory on the back of a new build house. When I say conservatory, its more like an extension. More brick than glass, with insulated, MetroTile roof.
4.1m x 3.5m external, so approx. 3.5 x 3.2 internal.
Part of the quote is for electric under floor heating. (Can`t do water for various reasons)
So based on the above, would electric under floor be enough to keep the room comfortable in the cooler months. And does it work OK under Laminate? The missus really wants Laminate.
Is it expensive to run?
On a room that size, would I just be better with a portable rad, or wall mounted fan heater?
I want to be sure, because if I understand correctly, Its going to be a bit of a faff to install.
Although supply is there for sockets and lights, I believe UFH needs a dedicated circuit. This means running armoured cable round the outside of the house to the consumer unit at the front, which I would rather not do.
I know the general consensus is that a water system would be better, but its just not a practical option at the moment.
Opinions/experiences would be very helpful.
