Caporegime
- 13 May 2003
- Warwickshire
I think magnolia has just invented quantum trolling.
no the cat is furious because you locked it in a box
That's my view too.A cat in a box is neither alive or dead (is both) until we open the box and observe it??. What a load of ********. The cat is clearly alive or dead in the box, we just dont know which one it is.
The point is that quantum mechanics is all based on probabilities rather than certainties, and the act of trying to measure the state affects the state. At least with our current technology.
I dont believe this to be true. The state is what the state is, and by observing it we simply know which one it is.
I have in my left hand a red ball and a black ball. I put one of them in my right hand.
The notion that my right hand contains both a red ball and a black ball until you observe it is absurd. The further notion that there is a divergance of reality at this point so that one reality is a red ball and one reality is a black ball is also absurd.
All you know if there is a 50% chance of the ball being black or red. The ball is one of them, and will always be one of them. Thats it.
The very act of looking can determine the outcome.
the outcome has happened whether we look or not.
And your evidence for this is...?
Yeah, your thought experiment wasn't that great.I just disagree with stupid thought experiments.
Your statement above is wrong or badly worded, the outcome has happened whether we look or not. The act of observing simply informs you what outcome has happened, it doesnt change the outcome.
No it hasn't, the act of looking at it determines the state before that it exists in a superfluity of states its in both states at the same time until you force it into one or the the other, thats the point. Photons or electrons will travel through both points at the same time until you observe it then it'll pass through one or the other. This has been demonstrated. Look up the collapse of wave function.
And you are correct, it is very, very silly. And very very wierd. Someone once said if you don't find quantum mechanics profoundly disturbing then you havn't understood it at all.
Going off on a slight tangent I find the double slit experiment quite interesting, where the observation of the atoms during the test, rather than just observing the outcome, will create a different outcome.
Quantum mechanics is mad![]()
I started a physics degree at uni many years ago and this kind of thing is why i didnt continue after year 1 and moved to engineering instead.
It is an example, not literal, and as such does not apply to the macro world
