Yea, I must admit that carving was a little tricky as I only had that little door way to slice through. I felt the part thoughThe size of that knife![]()
Maaaaaan i need one of them kebab cooker thingys![]()
But they're rubbish, chucked my down the tip last year. Just don't get hot enough. Need at least two heating elements I reckon.This thread makes me want to break this bad boy out again:
I've not used it in a while but mine wasn't too bad - maybe blow torching it from the open side might help? I do want to sort the gas one out to give that another try though.But they're rubbish, chucked my down the tip last year. Just don't get hot enough. Need at least two heating elements I reckon.
Yea, I must admit that carving was a little tricky as I only had that little door way to slice through. I felt the part though![]()
tempted by this got any picsI've since done a re-run, with added salt... came out a treat, I onle mixed by hand though, likely gives a much coarser texture? Held up well though and certainly on the cards for the upcoming BBQ season
I just put it in at about 160 four about 45 minutes.Had it in oven for 1 hour at 100 degrees so far.
What you guys reckon for time and heat? I dont really want to wait 4 hours tbh.
Was thinking of cracking to 120c and doing another hour.
If it's going to be cut then finished off under grill or fried then should be fine?
