- 30 Sep 2005
is snow foam better than TFR then? Have to admit, I've always used TFR and the dirt just falls off. Will look at snow foam if it's better (already have nilfisk jet washer)
I bought a good one and dilute it at least 9/1 IIRC. I thought it was good if the car hadn't been detailed in the past, or not properly cleaned in a long time.
Good for stripping everything off so you can start fresh so to speak.
Was going to get myself a nice second hand car when my lease goes back in September, but seeing how much damage seagulls can do to the paintwork, I think I'm just going to the tattiest car I can fine
Pretty sure they **** concrete.
Question for Nilfisk C110 owners:
Do you use the supplied tornado or powerspeed nozzle?
I know there's an auto nozzle sold separately too, made specifically for cars.
Hmm I'll have to see how it goes then, don't want to spend another £10 on a nozzle!Neither - I bought the auto nozzle which has a much wider fan at slightly lower pressure.
The powerspeed I think is ok to use though, but the tornado (the one that spins the water) will strip any paint imperfections (works great for cleaning my patio!)
tornado
Rubbish, powerspeed is perfectly fine for cars.
