Ryzen "2" ?
Why are you not using R15? why R11.5?
Cinebench R11.5 is known to have code in it where if it detects an AMD CPU it will deliberately gimp AMD's performance. here is the Anti trust https://www.ftc.gov/sites/default/files/documents/cases/091216intelcmpt.pdf
If you didn't know about this fair enought but now that you do use R15.
Got cb 15 but not with my all old cpus.
Ill dig u out CB 15 when home But if i my ryzen @3.95 is 166 HW was 174 or 175 if i remember good.
Yeah that sounds about right, my Ryzen @ 3.9 & Mem @ 3466 C15 gets ~160 CB 15 single thread.
worked fine on my phenom x3 and phenom x6 working good on ryzen. More or less same % difference as on R15.
Whats the Clock speed on the 5820X? because its significantly ahead in R11.5 while in R15 Ryzen is significantly ahead of the 5960X which is the same CPU with more cores.
The 1800X at stock is 15% ahead of the 5960 in R15, while the 5820 is 4% ahead in R11.5, in fact at 4.1Ghz the 1800X is 20% ahead in R15.
[QUOTE = "humbug, post: 31717577, membro: 130082"] In attesa : p[/ QUOTE]
This morning I worked a lot
I'm not referring to the computer but to my real work
I am a dental technician
I need half of my teeth pulling out :O
No, i mean you said
"30 minutes ready test of the ryzen 2700
Stay tune"
Touting for donations is bad mmmmkay.
Please read the rules, as next time it will be worse than an edit ;)
It was fixed via bios updates a few months in. Haven't had it for at least 6 months.
It would just loop a few times on boot before getting going.
Same here, I was a late adopter of Ryzen so I watched all the memory shenanigans play out before getting my 1600x, I've used 2 different motherboards which I did the relevant bio's updates on and I've never had a problem with my 3200mhz memory.
No was 3200mhz to 3700 mhz max
What you see I had activated max performace in windows ..
Same results in cinebench
sorry
if you want to remove donations address
Ah wait a minute i think i know whats happened here. :D
It says 4Ghz in CPU-Z which for a 1550 score... that's very low for those clocks.
But this is the 2700 at stock? 3.4Ghz all cores, the 4Ghz in CPU-Z was just captured when the CPU momentarily used its XFR boost, which must be 4Ghz.
4450 on cpu. All about Memory tuning people got no clue got to squeeze every drop of performance out of cpus.
Remember them pathetic cb15 scres of [email protected] that You posted like 100 points BELOW my 3950 ??
Think iw spend about 100 hours of memory fine tunign on my 5820k build. With ryzen EASY 300 hours of fine tuning and stability runs on multi bioses ect.
Anyhow Once I'm home ill run You CB15 got my old 5820k there also. YES ITS at lest 6 points faster than Ryzen there ALSO.
You got some CRAP scores on Intel platform same as You had crap scores on Ryzen.
My scores both times are BETTER with lower CPU clock
sorry
Any chance of ST run ??
Noticed IPC is not that much up !!! Looking at score of 1700 vs 2700x !!! 30 points more :P
I had temporarily activated maximum performance in windows
The test was done at default
Below you can see
thanks ill try give ya some bitcoins that my Ryzen+Titan are mining atm as I'm at work :)
Would be great if ya had time to run single thread test thats most important to Me at lest ;)
I can tell ya that when im gaming on my oculus rift GPU is botleneck not CPU :)
ha found photo of my Phenom X3 cooler the ASUS STAR ICE
Had extra fan added on back it looked like jet engine and... sounded like one :D
Haha, I used to have an old dual Athlon MP board with 2 of these, christ it was loud.
as soon as I can
now I'm back at work
at about 6.30pm, other test
