Depends how good Clocker You gotand how much extra 2 cores are worth to You in day to day basics
Guess budget got allot to do with it. If id be happy with 6 cores id get 8 pack binned 5ghz 8700kIt clocks 4.4 easy (1.25v) so yes it's a good chip. However, I'm looking to refresh my setup so it'll be Ryzen 2 or 8700k.
Guess budget got allot to do with it. If id be happy with 6 cores id get 8 pack binned 5ghz 8700k![]()
depends in whatBudget isn't an issue. Do you think 8700k @ 5GHz will have much over the new Ryzen? I'd be running 16GB Teamgroup 8pack RAM.
In games pass 100fps ye in production nope simple.
Considering Intel clocks 1GHz over Ryzen, there really isn't that much difference in game benchmarks.
Thanks, now we need someone with 1080Ti and Ryzen 1 to do the same![]()
At 5Ghz I would expect the 8700k to beat a ryzen 1 at 4.0Ghz at most things. But if they achieve 4.2Ghz+ the new chips should have a solid lead on anything that can use all 8 cores.Not so clear cut, esp at 5Ghz. I'd say it would prob be a draw in production work too.
eCLK mode - overclocking IF individually without overclocking DRAM (1 processor clock and 1 clock generator of the motherboard will be used). This is not confirmed information, 19th is soon, we'll find out everything
Interesting comment here from a BIOS developer for X470:
http://www.overclock.net/forum/11-a...vi-overclocking-thread-3503.html#post27145449
So possibility that we'll be able to overclock the Infinity Fabric separate to memory speed. Be great if true!
That would be very interesting indeed, although we have no idea what effect this'll have. It might be like base clocks on modern Intel platforms where you can only get a few MHz.Interesting comment here from a BIOS developer for X470:
