Should be same as any over launch, gets to 2pm then your youtube feed gets flooded by all the tech channels releasing their videos. OF RINGER CPUS.![]()
The easy upgrade path with Zen was what made it so appealing.
The new cpus fit, but the new chipset is supposed to support better mem speeds, better OC, plus the new precision boost stuff etc I believe.It should just be a drop-in for you Phil surely? And tbh, if you don't intend to upgrade your cpu for a while it might be worth going 2700x? Sorted for at least a few years then, no more messing just a gfx upgrade when required.
No reason to go 8/16 for me. Especially when 7nm Zen should be a must have if sticking to this platform.
first amd upgrade in 8 yearsi've just dropped £550 on the 2700x and the asus rog crosshair vii hero, i dont know why but i have a good feeling about ryzen2, i always miss out buying new components so i've made sure to get one, fingers crossedfirst amd upgrade in 8 years
I would be right cheesed off if I bought the 2700x to find that my 8 Pack ram still won't run at 3200MHz with my existing x370 board.
I thought it did with the cpu at stock but it doesn't.
Frooze on me after about 20-30 mins gaming last night.
Was considering the Taichi. Seen a few folks moan about bios options being a bit weak. Seen plenty moan about the Asus boards too so, eh, we'll see.
Dunno about the last two but the first two let you set various clock speeds for each power state. This allows your chip to downclock to save power even when overclocked (which should just happen anyway, like with Intel's chips). P0 is the highest power state. See this guide for more information.
Thank youDunno about the last two but the first two let you set various clock speeds for each power state. This allows your chip to downclock to save power even when overclocked (which should just happen anyway, like with Intel's chips). P0 is the highest power state. See this guide for more information.
