Caporegime
- 18 Oct 2002
What is the maximum stock all core boost on a 2700x?
Kitguru had it going over 4Ghz with an AiO, just under with the stock rgb cooler.
The maximum I get on my setup is 3975Mhz on all cores/threads as the maximum boost
Intel and AMD both advertise max single thread clock, which is not what Chewie was referring to.
It's sad how AMD have taken to lying about clock speeds, Vega was the same. They should only be quoting speeds that their hardware can reach out of the box not numbers that you might get if you get lucky and tweak it well.
AMD Ryzen™ 7 2700X Processor
Graphics Model: Discrete Graphics Card Required
# of CPU Cores: 8
# of Threads: 16
Max Boost Clock: 4.3GHz
Base Clock: 3.7GHz
Thermal Solution: Wraith Prism with RGB LED
Default TDP / TDP: 105W
Tell me more nashathedog.
Your understanding seems to be flawed but for some reason it's not stopping you calling them liars.
Tell me more @nashathedog.
Are you unhappy that OCUK is listing the Max Boost Clock and confusing it in your mind with AMD?
Flawed how?
The 2700x is meant to boost and hold 4.35 ghz which it doesn't, The Vega cards were the same, I owned 3 and none of them were able to reach the claimed boost speeds.
Worth keeping an eye on SSD performance if not using the Ryzen Balanced power setting. With my 1950X and Prime-A board, my SSD was reporting low IOPS according to the Samsung Magician bench tool when using the high performance option. Changing back to Ryzen balanced resolved it.Imo always use the high performance power plan with Ryzen, the power savings you get by going to balanced are marginal.
That's overclockers - Intel is here : https://ark.intel.com/products/126684/Intel-Core-i7-8700K-Processor-12M-Cache-up-to-4_70-GHzhttps://www.overclockers.co.uk/inte...ocket-lga1151-processor-retail-cp-63r-in.html
https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-3ac-am.html
They're not advertised the same (At least here).
Sure, in the details the information is there, but that's not how they're advertised.
It can reach a max of 4.3 with low enough threads. What makes you think it doesn't do that.
*removed the 4.35 which I copied from you, it's correctly 4.3.
Here you can see how frequency works for number of cores: https://en.wikichip.org/wiki/amd/ryzen_7/2700x
1 core reaches a max of 4.3GHz
8 cores reaches a max of 4.0GHz
Base is 3.7GHz
@Scougar @GrebothI haven’t been keeping up on all things Ryzen2 related. Do we known when we will see the B450 boards? As I’m looking at building my new PC in the next month or so and don’t really need an x470.
Confirmation on my end after a day of usage, having the CPU Load Line Calibration setting to Auto and using the Windows Balanced power profile rather than the Ryzen Balanced one gives me the best results.
