- 19 Oct 2008
Yep, I'm using an NVME.I'll try switching back to Performance after the next Windows update - thanks for the heads up on that.Haven't noticed any change in IOPS or sequential speeds between Ryzen Balanced and High Performance, but I'm also only on SATA SSDs, might be different if you have NVMe drives. If there's an issue, I reckon it will be mitigated by the Spring Windows 10 update since they're putting the Ryzen Balanced power plan changes into the default ones.
, at least according to Samsung's own software. I never tried any other benchmark tool. All fine now though using Ryzen balanced.
