Caporegime
- 18 Sep 2009
- Dormanstown.
The P7 settings only come into effect when you go into custom settings. They aren't the stock settings.
But the clocks are set? They exist before you go into custom because GPUZ picks them up.
Again, if I run the GPU at default and run a game, it runs the set 1632 clocks until it throttles, because the P7 exists and works.
Regardless of the "spec" they're set at 1632.
AMD might list the P6 boost speed (Which is probably more accurate given its out of the box setting) but they're all P7 at 1632mhz at stock on reference cards.
