You can for the square Supreme HF as it's compatible with the Supremacy brackets, but I don't think you can for the original Supreme though as it was a different shape IIRC?
Unfortunately we don't have any more mounting plates for this water block since it has been end of life for a long time and you are correct the supremacy mounting plate will not work with this water block.
sorry to reply on an old thread, but just to register, the original Supreme HF can be used on AM4 sockets with a little modification on the mounting plate and bracket.
Just check the original plate
There is space to drill the holes for AM4 mounting .
