wccftech so you know it doesn't need to be based in any fact or reality.
Could you link to AMD's public announcement of Vega 20 please, because I couldn't find one only rumour and speculation.
vega 20 is just Vega 10 with the missing FP64 added back in, and some small refinements.
It is aimed at HPC and wont hit the consumer space.
I don;t see the need for all this speculation. AMD publicly announced all of these some time back.
if its still "Vega" and the per clock figures is true then it would likely have to be a massive die with extra CU's which will still be bandwidth staved
It's only being talked about so far in HPC, but if it's capable of significantly higher clocks and 70% more performance in a similar power bracket, once production is up there is little to no reason not to release a gaming version.
The fairly natural assumption to draw from that is, Navi is close enough behind that a higher clocked Vega 10 on 7nm isn't worth producing for gaming cards. If it wasn't there would be no reason to produce 3 times as many cards and sell 2/3rds as Vega 64 v2.
Read the article. It is based on fact as the run has been verified. What's not known is if there was anything misread.
Sure the site is not reliable but they are only reporting on a run of 3dmark that actually happened on the 24th April and is an amd chip of some kind.
3dmark are not very good at getting it right.
I remember when they reported that I had a 3dmark score for a RX480 that would beat a Titan V lol, the bench software missed the fact that I was using 3 cards in crossfire.![]()
Article of conjecture and assumptions. Why do mods allow this tripe? As Kaap said, unreliable data.
If you read the article and from my own experience they have been pretty good at getting things correct with the last few releases. They were pretty spot on with the 480/580 and Vega. Mistakes do happen though but it's hard to believe that at this stage of the game it would misread Vega 64 so wrong. Maybe someone tricked it to do so. It's not just getting clocks wrong but everything pretty much. So I am to believe that it got clocks, vram, gpu Id and some other stuff as well.
I am open to this being a new AMD gpu but I don't know what. Vega 20 was rumoured way back to have over 6000 shaders so could just be that.
It isn't necessarily Bega64 though. It may well be Vega20, and it is reading the clocks wrong.
