- 18 May 2010
- London
what you mean?
I bought a 2600x and just put it in and played.
all default
You now have an option to tinker and tweak if you want but I dont, XFR2 just makes it fantastic
I adjusted the ram but thats like a minute in bios.
buy samsung bdie ram and your golden.
I didnt, I bought cheap ass 3000mhz corsair lpx last year.
No issue
I have 8 Pack ram, and have been fiddling with it for the past 3 weeks.
No end of issues.
Just setting DOCP wasnt enough for me. Freezing and crashing in games.
I think I have got to the bottom of it by finding the correct ProcODT to use.
But I've said this before when it passed stability tests but eventually fell over.
Only time will tell.
I'm also not finding it easy to go above 3200MHz. I tried what 8 pack suggested which is set DOCP change to 3333 strap and BOOM in his words. Except BOOM is what my PC does when I try to use it. 1.4v on the ram and fiddling with the ProcODT and still not stable.
I can even boot no issues at 3466MHz but same. Cant find stability.
I've tried Stillts timings and Ryzen calculator at different straps.
Not stable.
Someone else has a thread about the same issue on a CH6 board.
So it's definitely not plug and play for some.
Do you have an x470 board?
I have a x370.
Not planning on swapping my 32gb 3200 any time soon unless there's a huge price crash ^^; Unless we already know what X570 will bring, I'm happy with the feature set of X470.
imageupload
