Odd annoyance on start up.
11 Nov 2009
Edinburgh
On occasion when I boot up my secondary PC nothing will show on my monitor a Dell 27". Holding the power button down and switching off then restarting seems to fix the issue and I will not have an issue. This is sporadic problem with the PC/monitor and I am at a loss what it could be.
Specs are:
MSI B751A-E33
CPU i5-3750
GTX 960
4 Gb RAM
I am sure the PSU is 450W
Any thoughts?
Do you switch the monitor on after the PC? It might not be seeing the monitor plugged into the GPU so it's firing up the igpu on the CPU.
Although if the igpu is completely disabled this can't be the issue
Most of the time the monitor shows the normal booting screens, POST and Windows loading but on occasion all I will have is the figure 99 in the bottom right hand corner, I think that is what I see, unfortunately for the purposes of this thread it has booted perfectly this morning, as of course it would.:D
