OK cheers, I thought that might be the case.You need to upgrade the mech bay, initially you won't be doing that until after a certain priority mission.
Well, it depends. You might want to expand it a) for the extra tech points to speed up repairs, and b) because of you have two mechs take a pasting in a mission you might want to run out some spares rather than wait for them to be fixed. Or you might just like having options readily available without having to pull mechs out of storage and refit them.OK cheers, I thought that might be the case.
I'm quite enjoying my lance of HGN, BLG, ZEU and BLK. The black Knight as an energy boat can one shot most mechs with a called shot. 2LL and 5ML to the point. Zap! But some missions require speedier mechs so I keep a catapult, trebuchet, firestarter and jenner in reserve
I was talking specifically distance moved per turn, rather than evasion (stomping on apcs), but point taken on the ppc. I went with LL so I could have 80 damage at long range and use the mediums up close (the heat thing is a non issue then) although they are much better for close range shots than a ppc if I need alpha damage. Also, I can use one of them and a bunch of mediums where a ppc would constrain me to just using the mediums (although as you say I could take extra heatsinks to offset this). I might give it a go though.Don't bother - you'll get more mileage out of keeping a Piloting expert in reserve. If you want a fast mech, use a Shadow Hawk. They have good firepower for 55T, jump jets, and a good Pilot can get them to 5 pips evasion easily.
Also LLs are not a good weapon, they have terrible heat:weight:damage ratios. Take a PPC instead of two LLs, it does stability damage and + versions can OHKO with a head crit. Plus you'll have 3 tons extra for jets, armour or mods.
Loving this. Mechwarrior, Mechcommander, Heavy Gear and Shogo Mobile Armour Div were some of my fave games growing up. It's a bit slow-paced and I do miss the Clan tech (do want Timber Wolf!) but it's nice to get a Battlemech fix again after so many years.
I'm still in the early game and haven't completed the first priority mission. Do the environments get more varied? There is currently little scope for tactics besides just walking towards the enemy.![]()
Is there a way of seeing an actual value of the armour on a mech before you commit to a refit?
The armour value, currently i just refit and hope for the best.Money value or armour value?
