Permabanned
Hardly surprising there's little in it. That's a 1080 doing 4k lol. You could probably throw an atom into the mix and get similar results
Its just a comparison using that particular bench, not drawing any conclusions.
Motherboard chipset drivers and ryzen power plan or leave to Windows?
The RMA'd ram is still freezing.
How are you tuning your RAM? Have you tried the timing calc program?
Also this is pretty good for testing, very fast.
https://www.karhusoftware.com/ramtest/
Though its 10 euros.
Seriously, just buy a new mobo.
Forget ddr4 prices, have they seen gpu prices. £450 now gets you a mid to upper range gpu. Couple of years ago you could get 1080 equivalent 780 for less around launch. My third party wf3 780 was 420 new. 1080 620 less than a month after launch.
Told You i was 90% sure its not the ram but Motherboard.So it's official then. My set up cannot get 3200MHz out of the 8 pack ram.
The ram has been RMA'd and it still freezes in game after a while at 3200MHz. Knocking it down to 3133MHz seems (it needs more game time) to be fine however.
I'll just settle for that no point trying anymore. But the question still remains where is the bottleneck?
I had these ram issues with my 1700 so I replaced it with a 2700x. The ram is 8 pack ram which most run over 3200MHz. The mobo well others have this mobo and also run their ram over 3200MHz.
8Pack was suggesting in the memory thread that the infinity fabric can also be a limiting factor same as the IMC. But a 2700x with a crap infinity fabric?
I'm not convinced.
Which leaves just the mobo as the culprit. But there are people with this board running higher memory frequencies.
I guess there is such a thing as a mobo silicon lottery as well now.
Next time I will make sure to buy a more premium board.
But ITS NOT THE RAM he's on 3rd kit now and Second CPU. 100% its something with hes motherboard.How are you tuning your RAM? Have you tried the timing calc program?
@JJimmyJ i removed all intel stuff from windows 10 shut down pc installed amd board cpu booted up no problems then installed amd drivers 6 weeks later still running ok
My Infinity fabric starts to go around 3533 got memory pass over 2000% at 3600 IBT pass cinebench 3d mark ect. But cant pass Y cruncher or realbench stress tests.
I would not be that fussed at loosing 77mhz memory clock gain, just enjoy using the PC and forget about it!
