- 9 Apr 2012
Only gonna have it for two years on PCP so not gonna be long term. Does that help?
The stuff I listed will cost all of £50 or so for enough to last a few years, take about an hour to do and will generally minimise swirling etc and keep it looking nice.
Yeah thing is it's not chemical it's a pH neutral productSo I bought some Bilt Hamber Wheel cleaner and also some Sonax Wheel Cleaner and compared both. Used one on one side of the car's wheels each and the Bilt Hamber wins, hands down. So much more chemical reaction with the iron on the surface, it is more like Iron-X.
Yup. That's why I always recommend it.So I bought some Bilt Hamber Wheel cleaner and also some Sonax Wheel Cleaner and compared both. Used one on one side of the car's wheels each and the Bilt Hamber wins, hands down. So much more chemical reaction with the iron on the surface, it is more like Iron-X.
Yeah thing is it's not chemical it's a pH neutral product![]()
Some a-hole has rested their door against mine and left red paint behind, tried Meguiars stuff but it won't all come off, any suggestions?
Didn't really want to go too agressive as its only a year old, I'm surprised meguiars ultimate compound hasn't removed it to be honest, I apply it using a polishing sponge, should I use cutting sponge instead?I use Menzerna power finish to remove some defects from paint, works well on scratches and scuffs. You just add a little to a hand cutting pad and work until it's full broken down. You can go at it a couple times if needed.
http://www.in2detailing.co.uk/produ...nish-2400-pf2400-250ml-medium-cut-polish.html
The pad I use doesn't appear to be stocked any more. It's a Lake Country Orange light cutting pad, something like this would be fine https://www.juicydetailing.co.uk/hex-logic-orange-light-cutting-hand-applicator-pad.html
