Permabanned
Can you try disabling Windows Game DVR and full screen optimisations for one of your games and see if that fixes it?
Is this a part of Win 10?
Where can I find it please? I've looked but had no luck, I'm using Win 10 Pro.
Yep.Is this a part of Win 10?
Yep.
Start Menu > Settings > Gaming.
No, just do what i said above.Is it still recommended to disable xbox/game dvr stuff via the registry?
Radeon™ Software Adrenalin Edition 18.5.2 Release Notes
Fixed Issues
Known Issues
- Sea of Thieves™ may experience an application crash or hang after the initial splash screen.
- Brightness or white screen issues may be observed when playing The Crew™ on daytime maps.
- Shader Cache may sometimes fail to enable or may not correctly cache shaders for games.
- A limited number of Radeon FreeSync enabled displays may experience a blank screen when Radeon FreeSync is enabled in a game.
- Warhammer™: Vermintide 2 may experience an application hang upon changing resolution.
- Some zombie textures may fail to render in horde mode for Arizona Sunshine™.
- Some games may experience minor stuttering during gameplay when the Radeon ReLive Instant Replay feature is enabled and FRTC is also enabled.
- Radeon Overlay may not show all available features when some games are run in borderless fullscreen mode.
- The Witcher™ 3: Wild Hunt may experience stuttering during gameplay.
- Edited videos sometimes fail to appear in the Radeon ReLive gallery after switching tabs.
- Corruption may be experienced with OGL or Vulkan™ API applications on some Hybrid Graphics system configurations.
Driver Download
https://support.amd.com/en-us/kb-ar...e-Adrenalin-Edition-18.5.2-Release-Notes.aspx
AMD Issue Reporting Form - Submit Driver Bugs!
www.amd.com/report
I even updated the OP for the first time in... years.Great stuff thanks for posting Matt.
It rings a bell, so most likely yes.Evening
Is the issue with Subnautica (and apparently other unity engine games) since 18.5.1 being worked on? It crashes almost immediately on startup of the game.
Giz
Still on 17.11.4 and wont be bothering with any of these drivers until i see the word 'DayZ' in the release notes.
None of these Adrenalin drivers run well for me anyways.. but i'm thinking about switching to a Ryzen 2700x soon so maybe they will work fine with a fresh Win 10 install, will be glad to dump Intel after the performance i keep losing with all the patches and BIOS updates.
Is driver 17.11.4 fine with DayZ?
Checked this morning and we do have a ticket open for this issue.Evening
Giz
