I've had the avons and found them awful in the wet.
Goodyear as3 are fantastic for the money.
Probably not, whats wrong with PC5? You could get Michelin CrossClimates + as they are available in that size.Can anyone recommend a better tyre for an R56 Mini One in 175/65/15 than the Continental Premium Contact 5?
I can't find AS3 rear tyres in 275/35/19 non-run flats anywhere
Am I missing something or have they been discontinued?
EDIT - Found them on tyreleader, very good prices too. There are 3 different types of Goodyear F1 AS3 showing, they are all the non RFT versions but vary in price massively. The only difference between the two I want are one are BMW OE rated, and the others aren't. Is that hugely important?! Fox, looking at you as you rate these tyres highly and no doubt have bought them for the same car![]()
Nothing! I thought they would be the best tyres available in that size, but wanted other opinions. Both my mum and girlfriend have similar cars that will be in need of new tyres at some point in the near future.Probably not, whats wrong with PC5?
Yeah saw them there but they don't have them in the front size
EDIT - They do, but again, not in OE BMW fitting. Does that matter?
The BMW Marked Asymmetric 3 in this size is the RFT tyre. This is what I run on mine. As to whether it matters - I don't know - but I cant be bothered with the argument if there is ever an issue with the diff or something and the non BMW marked tyres get the blame.
It's absolutely fine actually.
Yes. 4WD cars must have identical tread depths across the axles.I've had a warranty claim for a new 4wd transfer box on a Mini Countryman, they did mention the tyres, it wasn't an issue if they were not star rated but they had to be matched in pairs.
Good to know, in my size (275/30 R20) only the run flat AS3 is available - ruled it out as having an RS5 didn't want to make the ride any harder/harsher than it has to be.
Other options are the Vredestein Ultrac Vorti or Falken FK510 - anyone got experience of these?
Worth a watch.
I've only had a pair of FK510s on the rear since January so not much use in milage (about 2000) They still look like new and grip exceeded my expectations so I'll definitely be getting the fronts to match when they wear out.
Thanks, I've seen that review but still heard mixed things on the Falkens - out of interest which size are you using? As per the review the larger sizes seem to have firmer side walls.
