But, but, what's the point unless it has at least 1000nits and true 10bit...![]()
None.
Gah, bought it yesterday at the full price. Oh well lol.Has Red Dead Redemption dropped in price recently on Xbox Store, if Im looking in the correct place it seems to be £8.24 currently.
I could have sworn it was around £20-25 not long ago, especially with the recent X patch.
Might pick it up at that price.
Samsung UE40MU6400 ~£400
Samsung UE49MU6400 ~£475
None.
In all seriousness, if it's pointless going for HDR with low nits and anything less than 10-bit, would I be better investing in a Samsung U32H850 32" QLED monitor?
I wouldn't really be able to say, as I don't know much about monitors really to say if it's worth it, but for these "HDR" TV's at that price point I wouldn't bother, it will not be an experience that is befitting the technology. IMHO TV manufacturers should not be marketing them as HDR as the performance on them tends to be crap.
snip
It's a good monitor so whatever you are going to do make sure to buy from a store with a good return policy so that you can return it hassle free if you are not happy with it.This is why I'm thinking I might be better investing in the Samsung QLED monitor mentioned in my other post. The colours on it are surely going to be far superior to any budget TV and for gaming it has Freesync and 5ms response time.
A wide colour gamut that can make a big difference as well.
I watched Transformers 5 yesterday on a modest Samsung MU6500 in HDR and was quite impressed. This TV by no means is a high end TV but was able to display the content much better than in SDR mode with very deep black, rich colour and noticeable highlights even though it only has approx 350 nits in brightness. The Samsung MU6400 was mentioned somewhere in this thread above doesn't have a wide colour gamut and this is important.
I don't think any HDR monitors are worth investing in right now.
I don't think they are.The MU6400 and MU6500 are identical specs, the only difference is the 6500 is curved...
+1 to most of what you say. Majority of affordable HDTV's are 8+2 not true 10 or 12 bit you would need a microscope or sit a few inches away to tell the difference anyway. As for NITS rating its also not that important right now I would be more concerned about local dimming zones (which is very hard to get info from the manufacturers) & being able to disable it as it causes a lot of issues on games especially.A wide colour gamut that can make a big difference as well.
I spent time with a few HDR TV's last month and I came to the conclusion that for less than a grand you won't get the best HDR experience but you can get a better experience than non HDR if the TV has a very good contrast ratio and wide colour gamut as the TV tone maps anyway. The brightness in HDR movies is a director's choice and sometimes doesn't go anywhere near 1000 nits.
A lot of TVs under a thousand aren't true 10 bits anyway and some in the know at avforums say it's not that important.
Extra detail can still be seen in shadows and clouds, sky etc with richer colour due to the wide colour gamut. Highlights are also present in lights and fire even at 350-400 nits.
I wouldn't spend over a grand on a LCD anyway and would rather wait for affordable OLEDS.
So if buying a TV for budget prices I would step up to a TV with at least a wide colour gamut and high contrast ratio so you could possibly get a nice picture regardless.
These are just my opinions and shouldn't be taken as facts btw.
HDR is a massive visual upgrade when implemented correctly (not bolted onto an older game like they did with Rise Of The Tomb RaiderPlayed Fallout 4 for well over 100 hours and no retention or burn on mine. Tbh I find HDR has more of a visual impact than the 4K resolution. Well done HDR looks stunning compared to SDR.
HDR is a massive visual upgrade when implemented correctly (not bolted onto an older game like they did with Rise Of The Tomb Raider).
What OLED do you have then I have read reports of a lot of gamers getting bad image retention from Fallout 4 as the in game control panel cannot be disabled (unless you play on the hardest difficulty).
Does the xbox one x support freesync
