- 18 May 2010
- London
I updated the title of thread.
Huh, really? I did it and upgraded from 16.04 to 18.04 that way.Apparently do-release-upgrade wont find a new release until LTS 18.04.1 which is coming in July, so i'll be waiting until then before i start upgrading my 16.04's.
Yeah, waiting until July seems like the sensible thing to do. Wait until any bugs that have slipped through have been fixed and then upgrade.
Not heard of that before. Does it come pre built with 18.04?I just discovered Lutris, oh man, it makes running Windows games on Linux so much easier, saves me time messing about with Wine settings to get stuff working properly since it applies configs for you.
Tested and played Hearthstone and WoW, ran well.
I would have held off on upgrading to 18.04 but I managed to borked my 16.04 installation, so, yeahalso needed to run 18.04 to test my post install script, so figured I'd go for it and test everything. It's running pretty nicely.
Lutris? Nah, you need to add repo for it then install it.
lutris.net is the site.
Thanks, will have a look.Lutris? Nah, you need to add repo for it then install it.
I'm actually switching to Fedora as we speak.
Preferring Fedora to be honest. Cleaner more professional look to it.
Ubuntu 18.04 felt a bit buggy and flaky to me.
Actually finding Fedora flaky as well. Lots of Gnome crashes and crash to login screen during install of VMsin vbox.
Fresh install as well. So I've opted for Centos 7 instead.
Ubuntu is good as a desktop, as Linux can get... its never going to be 100% Windows replacement, if you want Windows use Windows that is the bottom line...
I use Linux daily some of them Ubuntu and it is the best server OS out there, but for me Linux will be nothing more than a server OS to me in its current form
Stelly
