- 28 Dec 2017
- Beds
Well aside from only being able to use the first ~3GB RAM, yeahSpec 8Gb RAM for each machine and an SSD. Job done
If they struggle to run 32bit then 64bit is going to require more ram... ergo, it’ll be worse.
8Gb RAM on Windows 7 32-bit? Pointless, it won’t use anymore than it already is now. And I also don’t agree that SSDs are going to make much difference here. Spotify will be hammering that CPU into the floor. The other apps will as well. SSDs are great for disk access but I don’t see how that’s going to help in a situation where they’re using office applications and things like Spotify. How much disk access will be used whilst in Excel or Word? Hardly any. Sure, they might be running out of RAM but I’d say the most likely cause for the constant “not responding” is the CPU as the bottleneck. They’re only dual core CPUs from 2011. The architecture these days is pretty much useless when you start using most applications. Applications using .NET will chew through that CPU in no time!
One thing you can try in the interim is to disable visual themes in Windows. I’ve noticed recently on some Windows 7 PCs that they’ve been adversely affecting performance, causing similar issues to what you’ve described. It’s unlikely to completely resolve your issues, but it might make things more usable for the time being.
I've just checked and we've had them for 5 years not 2!
So I've had a chat to the manager and we're going to do a rolling replacement program and get some better machines.
So as above with the spec TheOracle just mentioned, should I look for an i3 or i5 with 8gb and an SSD and that will be good to last another few years?
Thanks, I found a guide to turn off some of the more intensive processes and it seems a little snappier.
Which i5 has hyperthreading?2018.. looking for future proofing.
Do not get a dual core machine... simply do not.
i5 hyperthreaded all the way, 8gb and pref an ssd if you can run to it.
I disagree re: SSDs. Next to boot times, general windows environment is where they make the biggest (and the most important) difference. Ssds can breath new life in to tired old desktops.
Kaby lake i5 has HT might be the refresh variant though.Which i5 has hyperthreading?
Andi.
Current standard staff desktop i buy in here at the campus i run is an i5, 8gb ram, 256 gb ssd and a 23" monitor.
Circa £500 quid for the lot.
Jeez, I could do the installs myself and I know roughly how to reconnect to the domain (haven't done it in a while though). I used to maintain the network a few years ago before we got these guys in, but it was smaller and hadn't been tweaked as much as it is now.
