- 28 Sep 2014
- Scotland
can you put all those bitmaps in spoilers - you just chewed up a page
Done fixed my post put all my images in spoilers.
You are missing the point - in 8 you have this dialogue:
https://www.simonsezit.com/article/configuring-windows-update-in-windows-8/
See the screen at the bottom with the options - the ability to block automatic driver updates also works and works properly and additionally with some very simple use of advanced configuration you can also granularly control the installation of security and feature updates so as to get security updates in a more timely fashion and feature updates deferred permanently to your convenience.
You can not do any of this out the box with 10 - at best some versions allow you some degree of being able to defer updates but the functionality is not reliable for blocking all Windows update behaviour and likewise even 3rd party tools aren't a complete solution especially as they've "hard-coded" some routines in 1703 onwards that currently no 3rd party tool disables.
Windows update in 8 will also completely obey any metered connection settings you configure - Windows 10 will not - for some people this is a big deal.
So there is a lot of difference between 8 and 10 in terms of Windows update implementation.
Look at the text description by the metered connection setting (smooth operation, critical updates blah exception) - they changed it around 1509 or so when they grudgingly gave back the ability to set wired connections as metered:
http://www.itprotoday.com/windows-s...tors-update-will-not-block-all-windows-update
They "claim" they won't send large updates but that is contrary to my experience where I had Windows update grab 2GB on my 4G when I was at work - when people set connection metering that is usually because they actually need to manage their connection usage and having the OS not obey that is unacceptable.
Other people have also claimed that sometimes it will still download between 1/3rd and 2/3rds of available updates even when it is set.
Hmmm my friend lived in village for 18 years now, he always wanted Virgin Media TV and broadband but it still not available in his area, he did not have BT phone line and he did not need it so he used his mobile phone with 3 Mobile sim free on 3G all the time. Last time I visited him 10 years ago at his house, he had Windows 7 Ultimate on his desktop PC for free from my TechNet subscription and also have wifi G card installed used his neighbours wifi signal to downloaded updates from Windows Update. Sometime when signal was very poor and he took his desktop PC to his mum house which got Virgin TV and connected his PC to Virgin Media broadband to download updates from Windows Update and Steam games updates. 10 years passed everything had changed now he used Windows 10 Pro and wifi AC card installed used either his neighbours wifi signal or BT wifi hotspots to downloaded updates from Windows Update and his iPhone 8 now used 3 Mobile on 4G network. He told me he very happy with Windows 10 and don't have issues with 1803.
Similar thing with my nephew worked in the UK army only used wifi on his Windows 10 laptop, everytime he went on holiday leaves he stayed at his single dad house just a few streets from me did not have Virgin TV, broadband or BT phone line as his dad cant afforded it. So my nephew used his friends neighbours wifi signal or used either BT or Virgin Media hotspots to downloaded updates from Windows Update, he don't have issues with it and already fully updated to 1803.
Did you find substantiation on the internet - like the multitude of win 10 update complaints
What the firm didn't mention, however, is that it drastically changed the way that updates are delivered with this version. Previously, if you hit 'Check for updates' and the feature update was offered, that meant that Microsoft had decided that your hardware is ready for it. This was the nature of a staged rollout, and if you didn't want to wait that long, you could use the Update Assistant or Media Creation Tool to force the process.
What's changed in version 1803 is that now, if you hit 'Check for updates', Windows Update assumes that you want to force the process. It's long been recommended that users install security updates on Patch Tuesday, but on May 8 when cumulative updates were offered, anyone trying to get them through Windows Update ended up with 1803, unless they waited for them to be delivered automatically or downloaded them manually through the Microsoft Update Catalog.
Microsoft didn't make a note in its blog post about how many people running the Windows 10 April 2018 Update likely initiated the installation by accident, causing problems for their device. No, the credit all goes to artificial intelligence, as the feedback from those users is what created the basis for other installations, and today's decision to make the update broadly available to all compatible devices.
And the company said that due to its new process, it's seeing "higher satisfaction numbers, fewer known issues, and lower support call volumes compared to previous Windows 10 releases." An example provided is when customers were noticing a black screen issue, Microsoft spotted the issue in its support forums (not telemetry, or even the Feedback Hub, for that matter), and within 24 hours, it blocked PCs that might be affected from upgrading to the new version.
If you want to upgrade your PC to Windows 10 version 1803, it should now be waiting for you in Windows Update.
I hope it isn't going to do this every few weeks while not a major issue it is still irritating.personally never/not having any problems with forced win7 gpu driver installs.
Multitude??? Nope.
.......very tiny Microsoft tool.
you had put forward your example of win7 forced gpu driver updates suggesting that was an indication of general win7 problems.
I contend people had few win7 problems in comparison to win10, so was asking for, where are the long (substantiation/)threads of win7 problems. ?
I guess you think most look back (well i still use it, after abandonned win 10 dalliances) at win7, with rose tinted glasses
Great but I'm not sure the relevance and/or don't think you've quite grasped the issue here.
Feed back hub on insider had atleast 3 entries about automatic updates with around 6000 up votes each - I've not checked lately. The official Windows 10 discussion forum has 100s possibly 1000s of complaints about it - I posted a screenshot recently showing 10-12 just on page 1. You aren't looking hard enough.
I've mentioned the minitool on these forums several times I think even in response to one of your posts but it doesn't give you proper control over updates or ability to pause or restart, etc. just some ability to reactively block problem updates. I can't believe you sincerely mentioned it in the context of taking control of Windows update it only addresses a subset of functionality.
I see, if you talk about Windows 10 ate your 4G mobile data allowance. Windows 10, Windows 8.1, Windows 8, Windows 7, MacOS, iOS, ChromeOS and Android all had same issues with 4G mobile data and 4G data roaming that you not quite grasped how massive the problem millions of people experienced worldwide after read so many horror stories about huge surcharges on mobile data and data roaming.
On page 1? Your post with screenshot was not in page 1 of official Windows 10 discussion thread
Now the 1803 update has "matured a bit".
Let's see how that is going for folks. Major SSD problems. Major "computers being bricked" problems (that'll teach 'em for using Avast). Still, people facing update lockups. Networking in shambles. Audio problems. Both Microsoft's built-in apps and third-party apps not working correctly. Mystery Drive letters. Microsoft store malfunctions. Language malfunctions. Settings changed. Drivers replaced. Restore points gone. Programs that worked prior to the update now will not work, no longer compatible. All of this still being forced on the masses.
I believe I am only touching on the highlights here.
And yet many here want to defend Microsoft and Windows 10. Have at it.
You said possibly 100s to 1000s of complaints about Windows automatic update did not added it all up, accorded to OCUK Windows 10 thread tool had 1063 members replied in that thread and I read every post and took notes counted how many members complained about Windows 10 automatic update, actually 18 members complained about Windows 10 automatic update so that is 1.8% which is very minority. Also 18 members complained about Windows 10 Start Menu which they hated so much, 8 members hated Windows 10 UI, 3 members wanted old control panel back but hated new control panel.
https://answers.microsoft.com/en-us/windows/forum/windows_7
https://community.spiceworks.com/windows/windows-7
https://social.technet.microsoft.com/Forums/windows/en-US/home?forum=w7itprogeneral
From 1 July 2018, Microsoft will no longer provide technical support to users on Windows 7 and 8.1 problems.
https://answers.microsoft.com/en-us...icrosoft/b1f5c5a4-7d66-4579-83bf-2b6ba599baaa
I was talking about page 1 of the discussion group on the official MS forums which I took a screenshot of and linked to in a recent post which you even responded to... I'll repost the image here
https://i.imgur.com/klsU6ml.png
There are many many people who are having a truly horrible experience with Windows 10 - many of the issues could be easily avoided by MS regardless of whatever you post - like wise most of these people myself included have made multiple attempts to get MS's attention over it - any attempt to contact a MS individual just gets you told to post on the feedback hub because apparently they are "listening" (which they aren't).
Here is just a couple of many many posts on the subject:
https://answers.microsoft.com/en-us...essageId=c9ca1f2c-20c0-45f9-a8b0-295480383c6e
https://answers.microsoft.com/en-us...essageId=deb9a95a-f3fb-4520-96da-6d1312074ed6
A great comment there:
You are going to crazy lengths to try and defend Windows 10 - that really should tell you something - also wasting your time with disingenuous arguments and beating around the bush you can just look at those two links above, then follow back to the main official forums and see that it is many many users regardless of any attempts to deflect with convoluted arguments and looking the other way.
I showed this thread to my friend IT teacher I told you and he were laughed at you at your pointless arguments, he told me it seemed everybody (teachers, pupils and his dad, cousins, all his friends included me) has a home laptop running Windows 10 Home don't have issue with automatic windows update. If you go to PC World site and you will find 243 laptops and 108 desktops running Windows 10 Home, millions bought these PCs and don't have a problem with automatic update. He suggested you to stop waste your time kept posted all pointless arguments on OCUK or Microsoft forum, you are the minority so he agreed with me that it is very good idea you should sent messages to Microsoft direct on either Facebook or Twitter so there the list again.
MS needs to FIRE the CEO Satya Nadella and his team and take ownership for the disaster
which is Windows 10.
All feature updates should be halted!
MS should return to the OLD update system IMMEDIATELY.
They should also apologize for the fiasco as well.
We're waiting MS.
