Undoing stuff.Whatcha gonna be using them for?
Be more specific you plank![]()
No, one turn to loosen them up and then just spin the handle with your finger.![]()
I'm with Dis86. I also dont see the point... if the bolt is loose enough to allow the handle to spin freely what's wrong with a normal screwdriver type handle? and what about confined spaces?? Only use I can see is for removing very loose long bolts... So what are you using them for???
It obviously has a mechanism that allows you to remove a bolt with very minimal effort, as well as tighten
When working on my motorbike, mainly when working on the fairing, wheels etc, both are too big for any tight spaces.Be more specific you plank![]()
But only if the movement of the bolt is completely unrestricted. Definitely not designed for automotive use for example!
Is that a 2 metre desk? Was thinking about getting one with the alex drawers but would like it to be suitable for 2 people to sit at.
Watch from 6:20 for how it works.Effortless.
You didn’t buy them so don’t worry about it.Effortless if the bolt is very free to spin... else still don't see the point.
foto_no_exif (11) by CosmicLogos, on Flickr
At first glimpse I thought that said Dellend ha ha
Nahhhh... that's just what I act like![]()
