What gpu? £200 budget
31 May 2010
Bedfordshire
Hi guys I am stuck in what gpu to buy.
Going to be upgrading for a HD7950.
Is the 1060 or rx 580 worth it?
Don't mind buying second hand from the MM (been looking at 980ti but they sell quickly)
I may have an option to buy a r9 nano off a mate.
What do you guys recommend?
Gaming at 1080p for now but hopefully going 1440p eventually.
Specs
4770k @ 4.4ghz
8gb ddr3
Corsair hx650w psu
Hi there
Over your £200 budget but extremely competitively priced in the market:
PowerColor Radeon RX 580 Red Dragon V2 8192MB GDDR5 PCI-Express Graphics Card @ £248.99 inc VAT https://www.overclockers.co.uk/powe...ddr5-pci-express-graphics-card-gx-18l-pc.html
AXRX 580 8GBD5-3DHDV2/OC, Boost: 1350MHz, Memory: 8192MB 8000MHz GDDR5, Stream Processors: 2304, DirectX 12 Support, AMD CrossFire, AMD Eyefinity, 3 Years Warranty
Only £248.99 inc VAT.
ORDER NOW
Palit GeForce GTX 1060 Jetstream RGB 6144MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT https://www.overclockers.co.uk/pali...ddr5-pci-express-graphics-card-gx-03l-pl.html
NE51060015J9-1060J, Core Clock: 1506MHz, Boost Clock: 1708MHz, Memory: 6144MB 8008MHz GDDR5, Stream Processors: 1280, VR Ready, PhysX/CUDA Enabled, 2 Years Warranty.
Only £229.99 inc VAT.
ORDER NOW
Specs
4770k @ 4.4ghz
8gb ddr3
Corsair hx650w psu
RX580 is the faster card.
I tend to buy second hand tbh, but just wanted to know what's best for my budget.
So 980ti >rx 580 > 1060 if I am reading it right.
What you guys think of that r9 nano? It's a slightly underclocked fury x?
thx chaps.
btw if i can get the r9 nano in my budget, is it better than the rx580?
No for two reasons
a) Needs to be watercooled
b) Ain't worth to side grade for the same money
c) if it was FuryX then yes by all means get it.
Have a look here, latest review with all latest drivers to the day of the review
http://www.guru3d.com/articles_pages/galax_kfa2_geforce_gtx_1050_ti_exoc_review,13.html
I had a heavily overclocked Nano is great card, but second hand from unknown sources ain't worth.
The poor thing might have been at the mines for years and HBM ram while good, ain't for long term mining. They get damaged
Eh? I had one a long time ago and it was perfectly fine for 1050mhz on air..
Yes but to make it worthy choice over the RX580, especially the red devil dragon, needs to be watercooled
Thx chaps. :)
Looks like a 580 is the way to go.
Btw panos, my mate has it, never been mined on and ran perfectly fine on air, thx though for the advice
