- 6 Jan 2013
- Rollergirl
@jammir nice effort there.
@crazyDAJT I would normally say drill a hole in the wall and get the radiator outside... that's proper water cooling, zero noise and zero heat.
However, in India you're probably better with the radiator inside.![]()
I don’t have aircon in my flat, but it’s not that bad, it’s only around 30C inside at the moment
A little ITX build. Just can't decide on coolant colour.![]()
That's impressiveA little ITX build. Just can't decide on coolant colour.
That's impressivewhat's the air flow like & your temps?
I've just spent the day wiring my new WC'd build in the Phanteks Enthoo Primo which could eat your case 3 times over and that was hard enough, think I'd have a melt down doing a WC build in that size case?![]()
Hey that looks pretty cool!Hi guys thought I’d share my first full open loop.
Ek fluid gaming 360g kit
Gpu is an evga 1080ti sc2 (slightly modded so the cooling block fits)
https://imgur.com/lXUcsVU
