Ryzen "2" ?
Thanks for heads up on the Asus BIOS - question will this reset all the BIOS settings I've changed? This happened the last time I updated the BIOS...
Also a Ryzen n00b question; what exactly is the benefit of AGESA code updates?
@AMDMatt
Hi Matt. Not expecting you to trouble shoot this issue but just guesstimate. Why does my Samsung B-Die Team Group 8Pack 3200Mhz ram not work at DOCP settings? I have a 2700X and a X370 Prime-Pro.
It is stable at 3133MHz but if I set it to 3200MHz using DOCP it will freeze eventually during gaming.
I tried for weeks and weeks to make it stable and even RMA'd the ram as I thought it was unstable. It was also exhibiting the same problems with my 1700.
Any remote chance that a future BIOS could solve the issue? Like a new AGESA.
@opethdisciple
I have a different board to you (Asus CH7) but also have Samsung B-die DDR 3200MHz.
Turning off 1T Command Control made the RAM stable for me at 3200 (although I am not using DOCP profiles, I am using Stilt's "safe" preset in the BIOS).
Su
@AMDMatt
AMD got NOTHING no do with Bioses. Told You 5 times or more tahy You got no chances od gettin that ram run with Yours board. Bors is crap id rma the board obviously its broken but seems You just cant take it in to brain that You have damages product and looking for solitions that dont AND WONT exist.
U can have another 5 AGESA updates and tou know what?? Wont do jpthing cause bord is broken.
@opethdisciple
Su
He does not have those presets thats perk pf ownig Crosshair boards. You should do dome calculator.magic for the ram kit. I know that Stilts presets are not best for teamgroup kits they are better for gskill.
Any board any bios update clears settings. You dould not like to have bricked board of it did not would You??
I was saying earlier in the thread that I couldn't get my b-die ram running at rated 3200 with a 2700X on the X370 Prime Pro.
Turns out reverting to the previous bios was all I needed to do - 4008 I think.
All running stable now.
I didn't get the crosshair vi from the MM due to a seller ****-up and was considering a x470 board but I think I'm just going to stick with what I have now. Maybe when boards with new feature come out I'll consider a move.
@opethdisciple
@opethdisciple
Cool. That's good to know.
There have been new BIOS's in the last few days for the CH6 and the CH7 so hoping the Prime-Pro gets one soon too.
Perhaps a stupid question, but anyone got any hard facts on Ryzen 3000?
I'm hurting for 1-4 threaded performance on my 1600X, but the motherboard is pants and I don't feel like a 26-2700X is really going to offer me that much in clock speeds anyway... Could be persuaded to swap to a premium board and stick with the CPU for a year if next gen AMD will be gunning for high 4s or even 5ghz. Otherwise I might have to flip this ol' coat of mine and pick up an 8700K while the delidded ones are on discount ¬_¬
