- 2 Aug 2016
- Third Earth
I’m seriously considering ditching Intel and for the first time in my life, getting an AMD CPU. TR2 flagship chip.
Definitely give it serious consideration. I hadn't own AMD stuff for a long time but been very impressed with the 1950X.I’m seriously considering ditching Intel and for the first time in my life, getting an AMD CPU. TR2 flagship chip.
With 1950 I run the 3200Mhz 14-14-14-31 8 pack memory, 32GB and it's completely stable with the cheapest mobo of the lot (Asus X399-A). I think TR2 will give better support for higher memory although not read into it yetWhat's the deal with RAM? Max speed/stability?
I think there some impact to max memory speed depending on the number or modules you have as well which is worth bearing in mind as more strain on IMCNice one, cheers. Time to design a whole new PC.
If you're running that many virtual machines then enjoy the switch to AMD - it's worth it.I would be looking at 64GB as I run about 4 virtual machines.
Not had a problem gaming on mine with a GTX 1070What's these like to game on then, would it be a waste of money to have as a pure gaming machine instead of a ryzen or 8700k? Is the clock speed letting it down?
I've run a few tests and there was only a few FPS in it at 1440P when testing a Titan X Pascal and a 1070 Ti. it wasn't a wide spread of games or benchmarks, so tiny sample, but I'd be surprised if anyone noticed a difference unless they're watching a FPS counter all the time.What's these like to game on then, would it be a waste of money to have as a pure gaming machine instead of a ryzen or 8700k? Is the clock speed letting it down?
