- 19 Oct 2008
Not been following the thread but did you try DOCP with the original bios? What memory is it, Mhz wise? If too high it might not be supported yet by mobo so may have to manually set it lower.Okay. First problem here. I flashed to 4011 BIOS, which seemed to go okay. Then I went back into the BIOS to set my RAM to run at its rated speed through its DOCP profile, and... it wouldn't even POST. Three or four failed POST attempts then it displayed a message that POST had failed, press F1 to enter setup.
I thought this Dark Pro 8 Pack RAM was guaranteed to run at its rated DOCP settings? What's going wrong here?
Ryzen 2600X on a Strix X470-F.
