OcUK Cinebench R15 benchmark thread
Last one i promise, i couldn't get the run to complete at 4Ghz. So 3.975Ghz is the last one.
1324 Points.
Good score!
Though on thinking for a 1.1 GHz clock advantage not that great tbh.
Wonder if AMD could pull another athlon with zen 2 (not the refresh)
>4 cores with strong single thread speeds was the aim of this build :)
Still toying with what to do with the 1700....... Bit overkill for a htpc i think.
I would have bought it off you for £165, same cost as a new 1600 :)
Unfortunately AMD price cuts have rendered the resale of my 1700 useless lol.
I'd get more value from doing something with it. Game server or something? Mining rig? Too many choices.
considering AMD don't split the whole vt-x (virtual machines with direct hardware access rather than abstracted software calls posing as hardware) and overclocking markets, consider doing something with a proper full virtual setup. Hypervisor and the works. You should be able to throw a pfsense firewall, server box, nas/media server and a guest gaming system in the same box with a bit of work with fairly minimal slow down on anything (obviously the guest gaming install getting use of whatever graphics card you throw in it).
With Intel you can't use VT-x on a K series processor (VT-d is fine though, has done me well enough for a 4 node Oracle RAC training rig).
As you wanted ideas...
Pfsense and a NAS server are things I could use..... Thanks I'll look into it.
Some say ryzen can't clock memory, and if you try to run xmp it won't even post.
All we know is they're a noob using the wrong board.
I score 3502-3511 with a 1950X at 4Ghz, with DDR4 running at 3200Mhz CL14. This is with no Cinebench tweaks and the 1950X running in UMA mode.
Haven't run this for ages but thought I'd use it to see how the hot weather is affecting my CPU temp (63C max after a few runs).
No idea why my multi-core score has taken a bit of a dive but my single core score is more-or less what it was last time. It'll do though.
If my 2700x at stock or overclock beats a 8700k (when compared to a stock or overclocked 8700k) then i will be happy and i seem to think that it will because for me it was a decision to either buy a 2700x or 8700k you see.
