- 11 Mar 2013
Any release date on this?
I hope they fixed the RGB lighting staying on when PC shuts down?
Maybe because there were not many RGB products to use except fans which were powered from other power sources? All I did was google and found the answers I posted. There are many other complaints about RGB / LED lighting in things like RAM, keyboard, etc. not turning off when system is turned off. Some saying it has to do with Win 10 and USB power changing staying on when computer is off with PSU on.I’ve never had a issue with any other rgb product. Just this one?
It's not a Cryorig H7 RGB lighting problem but a Windows 10 issue or default RGB light setting issue.
Here's what other s have said:
"By default when you shut down Windows 10, it actually ends all usermode stuff and puts the kernel and drivers into hibernate but actually in desktops, it keeps it in RAM and also writes a hiberfile to the disk.
So Windows probably not actually shutting down the system, an easy way to see if this is the issue is if after you do a shutdown, switch off the power supply, wait a few minutes/hit the power button to flush residual power, then flip the PSU back to the on position, if the lights stay off it's probably a hybrid sleep thing. If that's true you'll have to change those settings until it exhibits expected behavior."
And:
"Go to bios > Advanced mode > advanced tab > onboard devices > rgb lighting and you will see an option for sleep hibernate or soft off states set it to off."
Did you check your Win10 USB settings in device manager to see if USB charging is on or off when system is off? If USB charging in on then the power to the light will be on.I checked and I have none of those options on my mobo.
Gigabyte Z370 Aorus Gaming 7.
Cooler has no lighting control in it. Where do you have the cooler LED lead plugged in? My guess is the USB socket you have it plugged into does not turn off when computer is turned off. If you have more htan one USB header try plugging it into a different one.
@Robbie_G should be able to help mate. Although I think at the moment there isn't a date set in stone!
Hi,
Just trying to get the details of the launch. Sometimes these take months but I will let you know as soon as they reply.
Which releases cause feeling like this, eh?Just trying to get the details of the launch. Sometimes these take months but I will let you know as soon as they reply.
That is definitely the pace some manufacturers take from showing off a new product to actual release.
