I know, Audi, the ideal car for girls and estate agents, serious cars have rear wheel drive, like Mercs and BMW.
"Serious cars" as if most BMW drivers are gonna go for a B road blast in their 520d and explore the on edge handling dynamicsI know, Audi, the ideal car for girls and estate agents, serious cars have rear wheel drive, like Mercs and BMW.
"Serious cars" as if most BMW drivers are gonna go for a B road blast in their 520d and explore the on edge handling dynamicsHow can you order a car without driving one first? What if it's crap?
We call it 'rouge'Lipstick red too, not looking good for you.
It should do, yes. At 2015 it should have MMI 3G Plus I believe (joystick on top of the MMI jog wheel), which should allow for both Bluetooth and WiFi streaming, my 2013 A4 did.
My 2014 A5 has bluetooth to connect my phone up but cant listen to music through it. I have to hook my phone up using the MMI adapter in the glovebox to stream music.
The double DIN stereos aren't particularly difficult to remove, usually the same as your standard headunits (4 flat headunit removal tools). Simnply insert until you hear the click and then pull out.
When fitting a new headunit, Do reasearch and make sure you get the correct wiring harness adaptor![]()
Fitted a new one last night!
I got a Pioneer car Play one given how much I will use the car it is a no brainer. Although, I did have an issue with no sound... Turns out the car has an amp which is only activated by a blue 'Remote' wire, splicing these two together made the sound work.
The sound quality is mega, the car drives lovely. I'm actually really happy with it.
I'll try to get one up laterNice!!
Get a picture up, I'm interested how it looks, could be tempted to fit one to my wifes A3.
My A5’s built, and currently awaiting shipment to the UK.
....They reckon about 3 weeks time for delivery.![]()
but it will be well worth the wait!!go over and drive her back!My A5’s built, and currently awaiting shipment to the UK.
Having just bought a MK1 3.2 V6 Quattro TT, I can confirm I’m having massive fun in this weather (mines a roadster not a coupe). The engine makes a glorious sound and pulls well (nice to be driving a big-ish naturally aspirated engined car again). Assuming the MK2 in question is well specced and well cared for, I don’t think it’s a massive spend. If you like the looks, you like the drive, and you can afford it, go do it. It’s your money and you are only out to enjoy yourself!Evening. I need reassurance, I've been considering buying a mk2 tt 3.2 quattro. I have just over 7k, for this I can get a 07 or 08, around 60k miles. I was all set to go buy it when a friend said that's a lot of money for a 10+ year old car. It's really thrown me, is that really a waste of money? I can't really see anything else in that price range that I like. I would have a Gt86 but they start at around 11 so are out of my price range.
Can someone with a TT please tell me they are worth the money!
