Permabanned
- 23 Apr 2014
- Hertfordshire
Ah, they're nice boosts. The 1.5v+ Core Voltages are a bit alarming, but as you say, I've seen mine spike to that level. Are they regularly that high, or are those just spikes?
Can you set a negative offset with that at all, or is that the limit of volts/stability?
And no problems with PCIe or USB devices or drives at 103.4 bclk?
Those are just spikes. Thats with a very small negative offset. I need to play around with my settings, LLC etc and the offset to see if I can reduce it a bit as I just updated the bios to a new version and most things are on auto.
I have not had any issues with any devices so far, though I only have USB sound card, pci e wifi and the usual usb peripherals.
Low durability capacitors, low phase counts, high resistance mosfets... some of them won't push much more than 100amps to the CPU. TUF is the exact opposite of Tough.
