Hated that on C7H it was not glied had to use duck tape to hold it when putting block on !!!!Finally changed my CPU on my Ryzen 2700 to an AIO.
Why on Earth is the Asus Prime X370 Pro AM4 backplate "glued" to the motherboard?!
In general for overclocking, spec a good board. ££ spent on the board are more worthwhile than ££ spent on the processor.
Is it actually glued or is it perhaps just a bit stuck? don't pull too hard on it to find out :O
Do you need it off? the backplate on my ASRock was ideal for the AM4 bracket i had to purchase separately for £2.99 from OCUK so my now 3 year Kraken X31 would fit Ryzen![]()
Ha, I meant CPU cooler![]()
Where can I get one of these AIO cpus to replace my 2700x cpu?
It does give me a great idea that the cooling block is part of the cpu. Instead of the normal lid, combine the two
Oh they're very exclusive, have to be in the know to get one.![]()
if your watching amd or intel. I want ip royalties !
Yes I meant that the cpu itself was the block,, die straight to block, no lid, all in one. Was just a thought.Doesn't that just result in direct-die cooling?
Edit: or do you mean the cooling block is irrevocably sealed onto the CPU? Which I guess would allow for it to be specific dimensions that all cases and boards could accommodate for...
If you can solve the risk during installation (fiddling around with 300g of copper balanced on some teeny tiny pins) it's probably not a stupid idea...
I used to have the SLK-800 copper heatsink below clipped onto an AMD A462 socket. If you did it properly no issues. It was possible to break the corner of the die when removing it if you were careless.
2700x, on an x370 board. Didn't see any point moving to a 470, from what I've read it makes virtually no difference in terms of performance.
Mine was completely green screen and using the windows key to minimise the game and bring it back up again sorts it for awhile till it happens again.
I just remembered this conversation!
I did install Minecraft on the lad's PC in the end. He played about half an hour yesterday and it was all fine. No green screen issues at all.
Pleased to say also that I got his RAM running at 3200C16, which should make a nice difference from the 2133 it had decided to default to in the BIOS originally!![]()
cool, sometimes my son can play for an hour with no issues and then in the space of 5 mins get it twice and be ok for awhile again.
My bios is on default and only XMP enabled and 2GB dedicated to the gpu, oh and UEFI (secure boot) enabled.
Default is auto.Ah right. Well, I'll keep an eye out for it. Though I'm sure he'll let me know if anything goes wrong!
I didn't see the setting for changing the amount of RAM allocated tot he iGPU in the BIOS. Is 2GB the default?
Thanks buddy Do you mind sharing the settings they used for 3000 so I can set mine the same?FYI OCUK were unable to get 3200mhz on the team group. Best they could do was 3000mhz. Told to generally stay clear of team group for overclocking as I was considering changing the RAM. For the sake of 200mhz I've left it as it is. Should get it delivered tomorrow.
